3.1.x Extensions Database 3.1 / 3.2Partner Page
Superl
Re: Partner Page
Post by Superl »
Getting error updating
The migration "\dmzx\partner\migrations\partner_install" is not fulfillable, missing migration "\phpbb\db\migration\data\v320\v320a1".
killfrenzy
Re: Partner Page
Post by killfrenzy »
dmzx wrote: 10 years agoFirst post updated
What's new in update sir? Can also guest allow to view this partner?
Visit my blog http://androidcribs.com Androidcribs.comAndroidcribs Image
Re: Partner Page
Superl wrote: 10 years ago Getting error updating
Download updated :P
killfrenzy wrote: 10 years ago
Yes can set permissions
Superl
Re: Partner Page
Post by Superl »
Thank's work good now :eusa_dance: :buigen:
killfrenzy
Re: Partner Page
Sir where can I set permission?
    Ubuntu Firefox
Re: Partner Page
killfrenzy wrote: 10 years ago Sir where can I set permission?
Check the MISC Tab.
killfrenzy
Re: Partner Page
Check the MISC Tab.
haha I didn't noticed...lol Thanks a lot sir :thumbup:
alfi0815
Re: Partner Page
Post by alfi0815 »
where can I change the order??
t sorts only according to alphabet,
however, I would like to determine the order myself.
Googletranslate is my frind??
alfi0815
Re: Partner Page
Post by alfi0815 »
No idea like one the order can determine??
Thanks for Info..
Re: Partner Page
alfi0815 wrote: 10 years ago no idea like one the order can determine??
Thanks for Info..
No for now it cannot be determined will take a look if possible in net version.
alfi0815
Re: Partner Page
Post by alfi0815 »
:thankyou:
taledus
Re: Partner Page
Post by taledus »
This may or may not be a stupid question. I dislike editing the ext itself, because if there is an upgrade I am afraid I will break it's functionality...
That being said, all of the extensions that use the page-body have nothing there, so it displays on the background. I want to actually have it display in a container, so it matches everything else. On this extension in partner.css I can paste:
#page-body {
    position: relative;
    overflow: hidden;
    background: linear-gradient(#212121, #313131, #313131, #212121);
    padding: 5px 10px;
    border-radius: 7px;
And then it shows in that gradient container properly. I do not want this for my overall page-body, only certain extensions. How would I edit "#page-body" to use this in CssMagic instead of editng the root files of the extensions?
Re: Partner Page
Copy the css file from the ext and place it in cssmagic.css and adjust to suit your needs (if im reading i tright)
taledus
Re: Partner Page
Post by taledus »
Won't that edit everywhere that uses page-body? Like the main forum index page?
I don't want it on that one, but pretty much more of the other ones I do.
Edit: Like is there anyway to do:
partners.page-body {
    position: relative;
    overflow: hidden;
    padding: 5px 10px;
    border-radius: 7px;
taledus
Re: Partner Page
Post by taledus »
Here is what I did. Board Rules ext, boardrules_controller.html has <div id="container"> wrapping the entire rules section.
CssMagic:
#container {
	position: relative;
	overflow: hidden;
        padding: 5px 10px;
        border-radius: 7px;
        margin: inherit;
The in the Downloads, Partners, and FAQ I edited the html files to wrap in <div id="container">. Porbably not the best way to go about this, but I did not want this on my forum index page. This also makes it match the rest of the static pages created with Pages ext.
Edit: By default this displays on the navbar. Would like to request that it is optional, but it still works even if it is not on nav bar. That way I can just use the page link and make a Button for it on the Button menu ;)
