3.1.x Extensions Database 3.1 / 3.2Navbar
Null
Re: Navbar
Post by Null »
Jaantje wrote:
Null wrote:have I to install dmzx_navbar_quick_links extension too?
/ext/dmzx/navbar/styles/prosilver/template/event/overall_header_navigation_prepend.html
<!-- EVENT dmzx_navbar_quick_links -->
and place what you want, for example:
			<!-- IF S_USER_LOGGED_IN -->
				<li class="small-icon icon-ucp"><a href="{U_DM_SINKSHIP}">{L_DM_SINKSHIP}</a></li>
Thanks!
I changed that too:
<!-- IF not S_IS_BOT and S_USER_LOGGED_IN -->
to
<!-- IF S_REGISTERED_USER-->
Re: Navbar
martin wrote: it shows Jaantje
[phpBB Debug] PHP Notice: in file [ROOT]/ext/sniper/mobiledevice/event/listener.php on line 504: Undefined variable: status Fake phpbb debug error :rolling:
and every one else see's this
Jaantje is seeing a debug here only he can see it lol.
:eusa_dance: I see no bug on your board :rolling:
Re: Navbar
Not now no :rolling:
Re: Navbar
Jaantje wrote:I see no bug on your board :rolling:
martin wrote:not now no :rolling:
But you can check later. :rolling:
Re: Navbar
Love this extension! Thank you!! Now I can sort all games :)
Just one question, is there a way that I can change the order of the links?
I would like to place 'Arcade' before 'Puzzel'
Re: Navbar
Solidjeuh wrote:Love this extension! Thank you!! Now I can sort all games :)
You can add <!-- EVENT dmzx_navbar_quick_links_1 --> in overall_header_navigation_prepend.html for template events.
And let the games call that specific event.
so:
<li id="quick-links" class="small-icon responsive-menu dropdown-container<!-- IF not S_DISPLAY_QUICK_LINKS and not S_DISPLAY_SEARCH --> hidden<!-- ENDIF -->" data-skip-responsive="true">
<a href="#" class="responsive-menu-link dropdown-trigger">{L_NAVBAR_LINKS}</a>
	<div class="dropdown hidden">
		<div class="pointer"><div class="pointer-inner"></div></div>
		<ul class="dropdown-contents-navbar" role="menu">
		</ul>
	</div>
</li>
Re: Navbar
so:
		</ul>
	</div>
</li>
Great! Thank you! :D
cisco007
Re: Navbar
Post by cisco007 »
Nice and simple, great extension! :tumbsyes:
nelflucifer
Re: Navbar
Post by nelflucifer »
I think that could be done in the Admin panel (ACP) the possibility to add other GAMES/sections for this extension. You can implement the code. Or even how... Know that you can handle, but I would like more automaticity through ACP.
English Forums
TWEagle
Re: Navbar
Post by TWEagle »
Is it possible to make an ACP add link option??
nelflucifer
Re: Navbar
ru.zip
Austeyr
Re: Navbar
Post by Austeyr »
Hi guys is there a way to remove links from main phpbb nav and then add them to this ext
Example see all my links
id like these links to all show in this extension instead of where they currently are showing.
My phpBB Forums Top Ad Coop & Gamer Raid
I Run Several Advertising Websites. Find Out More & Get Advertising For Your Forum for FREE Share My Ads
Re: Navbar
Austeyr wrote: 04 Dec 2016, 00:56 Hi guys is there a way to remove links from main phpbb nav and then add them to this ext
See viewtopic.php?p=4924#p4924 and try that.
A
Hartenheer
Re: Navbar
Post by Hartenheer »
Mijn Engels is knudde en snap weinig wat ze met die scrips bedoelen.
Kom er niet uit hoe je de linken onder de extensie moet plaatsen.
Liefst zonder icoontje.
Wie kan me op weg helpen?
Re: Navbar
Hartenheer wrote: 16 Dec 2016, 16:38 Mijn Engels is knudde en snap weinig wat ze met die scrips bedoelen.
Zie je nieuwe navbar wel in header ?
Als he een link erin wilt plaatsen moet je de template dmzx_navbar_quick_links.html noemen.
Dus zet de code van de link daarin.
