Author: VSE
Extension description: This extension will show users how strong (or weak) their password is as they type it into the password field when creating or updating their account.
Password Strength Tests:
Password Strength now offers two types of strength checking models to choose from:
- Complexity:
A simple test to check for complexity in a password by looking for a mix of characters, case, symbols, numbers and length. This is useful for encouraging hard to remember complex passwords. - zxcvbn algorithm :
As used by DropBox, an algorithm that calculates the guess-ability of a password by comparing it to a large dictionary of common English words as well as looking for recognizable word patterns. This is a more robust strength checker that allows for user-friendly passwords that are easy to remember but still hard to guess. A Very Strong result represents a password that could take a computer years to centuries to guess.
- Password field changes colors from red (weak) to green (strong) as the user types in a password.
- Password strength is labeled as 'Very Weak', 'Weak', 'Good', 'Strong' and 'Very Strong'.
- Active on new user registration, and in the UCP and ACP areas where you enter new passwords.
- Set up Password Strength in the ACP User registration settings -> Password strength type.
- Multiple languages suported.
- phpBB 3.1.x (all versions)
- phpBB 3.2.x (all versions)
- phpBB 3.3.x (all versions)
Extension version: 1.2.3
Download file: vse_passwordstrength_1.2.3.zip
File size: 833.79 KiB
Source: [url]https://www.phpbb.com/community/viewtopic.php?t=2542496&p=15440631#p15440631
