Author: AbaddonOrmuz
Extension description: Auto-lock topics after the specified number days of inactivity using a phpBB cron task.
Features:
- Run the auto-lock cron task only in the selected forums
- Enable/disable announcements auto-lock
- Enable/disable polls auto-lock
- Enable/disable stickies auto-lock
- Set the number of days of post inactivity to trigger the auto-lock
- Set the frequency between auto-lock events
- Support for Move Topics When Locked (since 1.1.0)
- php 5.6 or greater
- phpBB 3.2 or greater
- Spanish (Formal Honorifics) [es]
- Spanish (Casual Honorifics) [es_x_tu]
If you like or found this extensions useful and want to show some appreciation, you can consider donating.
[ Donate via PayPal ]
Extension version: 1.2.0
Download file: alfredoramos_autolocktopics_1.2.0.zip
File size: 16.39 KiB
Source: [url]https://www.phpbb.com/community/viewtopic.php?t=2542476&p=15440446#p15440446
