3.2.x Extensions DatabaseConfirm Username
<span class="qte-attr qte_32-qte">3.2.x</span>
Referrals: 48
Confirm Username
Post by dmzx » Aug 8th, '19, 16:54
Extension Name: Confirm Username
Confirm Username at registration.
Confirm Username v1.0.0
  2. Unzip the downloaded release, and change the name of the folder to `confirmusername`.
  4. Copy the `confirmusername` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at
    (your forum root)/ext/dmzx/confirmusername/composer.json
  6. Look for `Confirm Username` under the Disabled Extensions list, and click its `Enable` link.
