3.1.x Extensions DatabaseTotal Attachments Downloaded
<span class="qte-attr qte_31_32-qte">3.1 &amp; 3.2</span>
Referrals: 48
Post by dmzx » Sep 6th, '15, 08:37
Extension Name: Total Attachments Downloaded
Special Thanks to: martin
This extension shows total attachments downloaded on index.
downloadsystemcat?id=39
  2. Unzip the downloaded release, and change the name of the folder to `totalattdownloaded`.
  4. Copy the `totalattdownloaded` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at (your forum root)/ext/dmzx/totalattdownloaded/composer.json
  6. Look for `Total Attachments Downloaded` under the Disabled Extensions list, and click its `Enable` link.
This topic has 8 replies
