Support Request Support[phpBB Debug] PHP Warning
Support Section
YellowFlash
Post by YellowFlash »
Your phpBB Version: 3.2.2
PHP Version: 5.5.6
Nothing
Trying to set the cache permissions to 777, also the production too
[phpBB Debug] PHP Warning: in file [ROOT]/phpbb/di/container_builder.php on line 146: require(./cache/production/autoload_4335734bbdd20f586549a504dff5f80c.php): failed to open stream: No such file or directory
YellowFlash
Re: [phpBB Debug] PHP Warning
Solved it
Posey
Post by Posey »
I'll reply nevertheless, for people having the same issue.
This is a 'cache' issue, which aren't really issues.
Most of the time it can already be resolved by a 'force refresh', which can be done by Ctrl + F5.
Otherwise delete the files starting with container_ in your <root>/cache/production/-folder.
''I'm pretty sure there's a lot more to life than being really, really, ridiculously good looking.
And I plan on finding out what that is.''
posey
Jester
Post by Jester »
Posey wrote: 8 years ago I'll reply nevertheless, for people having the same issue.
+1 :tumbsyes:
