Ask AI ⇒ Most popular extension
- Donator
AI
Re: Most popular extension
The "most popular extension" is highly subjective and depends entirely on the context you're referring to!ivailo95 wrote: Most popular extension
However, if we consider browser extensions, one of the most widely used and impactful categories would be ad blockers.
- A prime example is uBlock Origin, known for its efficiency and effectiveness in blocking ads, trackers, and malware sites across various web browsers. It's consistently ranked as one of the most popular and recommended browser extensions.
If you're asking about extensions specifically for the phpBB forum software, it's much harder to pinpoint a single "most popular" one. The popularity of phpBB extensions (formerly known as "MODs" or Modifications) often shifts with new phpBB versions, community needs, and what functionalities are integrated into the core software.
However, historically and currently, certain types of extensions consistently rank high in demand due to their utility:
- SEO (Search Engine Optimization) Extensions: These help make forums more visible and friendly to search engines.
- Anti-Spam/Security Extensions: Essential for combating unwanted content, bots, and protecting the forum from various threats.
- Portal/CMS Extensions: Allow forums to integrate with a front-page portal or a more comprehensive content management system.
- User Experience Enhancements: Such as advanced profile fields, private messaging improvements, custom BBCodes, or notification systems.
- Attachment/Gallery Extensions: For better media management and sharing within the forum.
- Donator
AI
Hello!
I understand you'd like me to use phpBB BBCode formatting in my answers, and I can certainly do that for you!
BBCode (Bulletin Board Code) is a lightweight markup language used to format posts on many forum software, including phpBB. It's a simpler alternative to HTML, designed to be easy to use and secure.
Here are some common phpBB BBCode tags and how they work:
- Bold Text: This text will be bold.
[b]This text will be bold.[/b] - Italic Text: This text will be italic.
[i]This text will be italic.[/i] - Underlined Text: This text will be underlined.
[u]This text will be underlined.[/u] - Strikethrough Text: This text will be struck through.
[s]This text will be struck through.[/s] - Colored Text: This text will be red.
[color=red]This text will be red.[/color] - Sized Text: This text will be larger. (Sizes are often percentages or specific pixel values depending on forum configuration)
[size=150]This text will be larger.[/size] - Links: https://www.phpbb.com or Visit phpBB.com
[url]https://www.phpbb.com[/url]Code: Select all
[url=https://www.phpbb.com]Visit phpBB.com[/url] -
Images: (This is a placeholder image for demonstration)
[img]https://www.phpbb.com/styles/prosilver/theme/images/phpbb_logo.svg[/img] - Quotes:
This is a quoted passage.
[quote]This is a quoted passage.[/quote]Author Name wrote:This is a quote attributed to someone.Code: Select all
[quote="Author Name"]This is a quote attributed to someone.[/quote] - Code Blocks:
function helloWorld() { echo "Hello, BBCode!"; }[/code]Code: Select all
[code] function helloWorld() { echo "Hello, BBCode!"; }
(Note: To display theCode: Select all
tags themselves, they need to be nested inside another [code] block.) [*] [b]Lists:[/b] [list] [*]Item 1 [*]Item 2 [/list] [code] [list] [*]Item 1 [*]Item 2 [/list]- Numbered Item 1
- Numbered Item 2
[list=1] [*]Numbered Item 1 [*]Numbered Item 2 [/list]
