Support ⇒ Support Request Transfer Mchat settings not working
Support Section
Corleone
Post by Corleone »
Your phpBB Version: 3.3.15
Your knowledge: Beginner
I set this option in the ACP to No
Enable posting in mChat for transfer:
Post transfers from members.
Purged cache
Purged cache
Purged cache
Hi, I've set this option in the acp to no Enable posting in mChat for transfer:
Yet I am still get the auto messages at times from some users. For example I just sent a transfer right now, and no chat message appeared, but earlier today there was an auto message posted from another user who sent a payment.
Are there additional permissions that must be adjusted?
Re: Transfer Mchat settings not working
Only these so set them to no then purge the boards cache.
Corleone
Post by Corleone »
martin wrote: Sep 18th, '25, 23:29 Only these so set them to no then purge the boards cache.
Thank you for your response. Those were already set to no, so the points transfer message is getting through despite those options.
Corleone
Post by Corleone »
This is the setting in ACP that I'm referencing. Even though this is checked to no, we're getting some messages in the mchat.
Corleone
Post by Corleone »
So since it's still auto posting for transfers, I just ended up commenting out the code in points_transfer.php, think that should solve my issue.
