Your knowledge: Beginner
Boardlink: https://bgrock.eu/index.php
PHP Version: 8.3.20
Nothing, just want to change toptic status and saw error
Nothing
[09-May-2025 03:29:11 Europe/Sofia] PHP Deprecated: htmlspecialchars_decode(): Passing null to parameter #1 ($string) of type string is deprecated in /var/www/html/ext/orthohin/navbar/event/listener.php on line 167Code: Select all
[09-May-2025 03:32:51 Europe/Sofia] PHP Deprecated: Optional parameter $replacements declared before required parameter $revert is implicitly treated as a required parameter in /var/www/html/ext/dmzx/editor/editor.php on line 44Code: Select all
[09-May-2025 03:33:15 Europe/Sofia] PHP Deprecated: Creation of dynamic property halferty\dropdownmenus\event\listener::$handler is deprecated in /var/www/html/ext/halferty/dropdownmenus/event/listener.php on line 35Code: Select all
[09-May-2025 03:33:15 Europe/Sofia] PHP Deprecated: Creation of dynamic property halferty\dropdownmenus\event\listener::$dropdownmenus_table is deprecated in /var/www/html/ext/halferty/dropdownmenus/event/listener.php on line 44https://youtu.be/D75tixSuKKs
