Questions ⇒ Question Topic Image ext
Topic Image ext
Hi DM wondering if it is possable for your Topic Image ext to grab the images from this ext "Magic OGP Parser"
here is an image and I will zip the ext also.
I think Vv is also interested in this
ger_magicogp_1_0_6.zip
Re: Topic Image ext
Got it working but it takes the image direct from www.imdb.com
Only strange thing is https://www.imdb.com/title/tt5834204/ will give other image than on imdb.com.
Will check how this image is taken..
Result in:
Others work ok in example
Re: Topic Image ext
Hey thasnks for taking the time :)
I am sure you will figure it out completely :)
I really don't know if it makes a difference I don't see where the imdb.com image is actually coming from for that image as I can't find it...
Will it still grab [img ] tags as well?
Re: Topic Image ext
It works now like an if.
if imdb then it grabs that image first, if no imdb then the normal post text [img]
need to check some things :wink:
Re: Topic Image ext
dmzx wrote: May 22nd, '25, 17:36 It works now like an if.
Hey that sounds great, Vv will love it I think, me to :)
