Support ⇒ Support Request Donation Extension remove user wrong time
Support Section
tmjeletronica
Post by tmjeletronica »
Your phpBB Version: 3.3.11
Boardlink: tmjeletronica.com.br
PHP Version: 7.4.33
Install on december, on live board, but use on January 2025 for users.
Not remember an especfic moment.
I removed extensions, purgue cache, reconfigure and update db to remove any issue on instalation, bu not works.
I have an sequence of the actions from my board removing users before time expires.
and, sometimes not has actived automaticaly group with donation.
I guess that on donation from the user maybe change group , but seconds later the own board remove automaticaly user from group donation.
Can someone help me?
image error
Re: Donation Extension remove user wrong time
This will be solved in next release, v1.4.4
tmjeletronica
Until 03/15 I'll make a new donation to upgrade my extension.
Thanks for explanation
