Support ⇒ Support Request mChat
Support Section
Ronald
mChat
Post by Ronald »
Your phpBB Version: 3.3.10
Your knowledge: Beginner
PHP Version: 7.3.33
adding arcade games
Disable mChat
Forum was working then over night I hot a 500 error message. Managed to get into the site, seen a mChat error code. Disabled mChat, site came back online
This is the mChat code error I get:
Parameter "ip" for route "dmzx_mchat_page_whois_controller" must match "[^/]++" ("" given) to generate a corresponding URL.
miri4ever
Re: mChat
Post by miri4ever »
Did you want to add highsscore from your Arcade Game to M Chat for Display?
Then you need to do this fix:
Mchat fix:
Open: ext/dmzx/mchat/core/mchat.php
Find
'MCHAT_U_IP'				=> $this->auth->acl_get('u_mchat_ip') ? $this->helper->route('dmzx_mchat_page_whois_controller', ['ip' => $row['user_ip']]) : false,
Replace with
'MCHAT_U_IP'				=> $row['user_ip'] && $this->auth->acl_get('u_mchat_ip') ? $this->helper->route('dmzx_mchat_page_whois_controller', ['ip' => $row['user_ip']]) : false,
Ronald
Re: mChat
Post by Ronald »
miri4ever wrote: Oct 11th, '23, 14:34 Did you want to add highsscore from your Arcade Game to M Chat for Display?
Mchat fix:
Find
Replace with
Thanks, I made the changes, will see what happens.
Ron.
