Should I run some kind of migration for the database ?
What I did:
1) Deactivated version 1.3.1
2) Uploaded new extensions (auto groups and configs).
3) Uploaded version 1.4.0
4) Reactivated extension.
I did not uninstall the old one or installed the new one..
Support ⇒ Support Request Donation extension problems on phpBB 3.3.10
Azatotht
Re: Donation extension problems on phpBB 3.3.10
For now you did it good, leave like this and check if all other things work.Azatotht wrote: May 19th, '23, 13:14 Should I run some kind of migration for the database ?
What I did:
I will look into this also here.
Azatotht
Understood, thanks.
- Donator
In ACP this part, do you have it in sequence? That made a difference for me.
Can you check database table donation_donors if field donation_date has times?
Azatotht
Just did a cache clear and reloaded donors list and I think the fix you told me (making group default) worked.
We'll leave it at that and I will wait for the next contribution to make sure that it is indeed working fine now.
For your other questions:
Yes the sequence is good:
And I have times in the donation_date field:
Ok good to see its working, let me know next works also.Azatotht wrote: May 19th, '23, 13:31 Just did a cache clear and reloaded donors list and I think the fix you told me (making group default) worked.
Azatotht
Will do thanks a lot !
Oh and there is a new button in the posts options now that I didn't have before, pretty nice
Yes some nice updates in code after 1.3.1Azatotht wrote: May 19th, '23, 13:40 Will do thanks a lot !
Oh and there is a new button in the posts options now that I didn't have before, pretty nice![]()
Azatotht
Maybe one last thing for you if you know how to solve this easily.
After the update to new version of phpBB, there is a conflict with font awesome fa-spin class.
I had a blinking heart before but now it spins. I think the css for font awesome being loaded before the extension css is causing that (not sure if it's phpbb or my theme that does that).
