Your phpBB Version: 3.3.10
Your knowledge: Beginner
Boardlink: https://palqk.eu/
Just enable 3 ext
Nothing
These 3 extensions give same error
viewtopic.php?t=1633
viewtopic.php?t=861
viewtopic.php?t=849
Support ⇒ Support Request 3 extensions give same error
- Donator
Re: 3 extensions give same error
They need an update if i have time tonight il do them. Note these ext's are for 3.2 also.
Installed and tested on phpbb 3.3 php 8.2.
- Donator
2nd and 3rd ext can't work fine
Never mind, i see it
my board doesn't work in php 8.2
Log out then back in and info will show.
- Donator
Work fine, thank you
by the way, how users can add text in "did you know"
