3.2 & 3.3 Extensions DatabaseUltimate Blog
Ultimate Blog
Extension Name: Ultimate Blog
Author: mrgoldy modified by dmzx
Ultimate Blog extension for phpBB
Will add them soon.
ultimateblog_v100.zip
  2. Unzip the downloaded release, and change the name of the folder to `ultimateblog`.
  4. Copy the `ultimateblog` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at
    (your forum root)/ext/dmzx/ultimateblog/composer.json
  6. Look for `Ultimate Blog` under the Disabled Extensions list, and click its `Enable` link.
This topic has 40 replies
