3.2.x Extensions DatabaseNavbar 3.2.x
Navbar 3.2.x
Extension Name: Navbar 3.2.x
Special thanks to: martin & Sniper_E
Extra navbar select menu use dmzx_navbar_quick_links as event to add the links.
Change language file to whatever you want the call the navbar menu.
See "Games" menu in navbar here.
Navbar 3.2.x v1.0.0
  2. Unzip the downloaded release, and change the name of the folder to `navbar`.
  4. Copy the `navbar` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at
    (your forum root)/ext/dmzx/navbar/composer.json
  6. Look for `Navbar` under the Disabled Extensions list, and click its `Enable` link.
This topic has 82 replies
