Displays reset and cancel button in posting buttons.
Reset => Clears the text field.
Cancel => Will return to Topic.
Update code, validation version.
Update code for 3.1.6-RC1
Added memberlist_view_contact_before for contact / statistics in viewprofile
Added Cancel button
- Download-link
- Posting reset button v1.0.4
- Unzip the downloaded release, and change the name of the folder to `postingresetbutton`.
- Copy the `postingresetbutton` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at
(your forum root)/ext/dmzx/postingresetbutton/composer.json - Navigate in the ACP to `Customise -> Manage extensions`
- Look for `Posting reset button` under the Disabled Extensions list, and click its `Enable` link.
