Off-TopicHow to fixed extension BGTOP
All the various Off-Topic crap here ;)
HarveyWNvm LLC.
Re: How to fixed extension BGTOP
Post by HarveyWNvm LLC. »
That's why I posted the code to help me because I broke it without wanting to and now I've put it back again
nFL-Cs.InFo Clock to Banner
"description": "Made by appunlockstoryplay.top", needs to be "description": "This extension adds something to the index page, What?",
You put a short description of what this extension adds to the forum.
In these lines "php": ">=8.2.14" and "phpbb/phpbb": ">=3.3.11,<4.0.x*@dev"
You are using the latest version of php and the latest version of phpBB - Most extensions uses the earlier versions of both that this ext works in.
"display-name": "BGTOP by HarveyWNvm", needs to be the extension name only which shows in acp. Scratch the by HarveyWNvm part.
But I don't see anything that could be causing your error. What does you error message say? You can't hold back information if you need help.
HarveyWNvm LLC.
I feel like I need a little help to get the extension to show on top 3.3.x It just shows on top that the version runs on 3.2.x And that's what I want to fix
