Support Request Supportmchat buttons changes forum button colors
Support Section
Neves
Post by Neves »
Your phpBB Version: 3.3.11
Your knowledge: Beginner
Boardlink: http://nevesprojects.com/
Enabling the mchat buttons ext. changes all my forum buttons color from this
to this
Is there a fix to this ?
I'm using the dark_vision theme by Kirk
Re: mchat buttons changes forum button colors
The look of those buttons come from the mchatbuttons/styles/prosilver/theme/mchatbuttons.css
You would need to look in dark_vision/theme/buttons.css and copy those button codes to paste in mchatbuttons.css
Unless you run prosilver on your site also. Then you would have to make a directory for dark_vision and edit those files.
--- OR ---
Open mchatbuttons/styles/prosilver/template/event/index_body_markforums_after.html
Change both class="buttons to class="button
Neves
Post by Neves »
Thanks :thumbup:
