Your phpBB Version: 3.3.11
Your knowledge: Beginner
Nothing, Not a clue on what to do
Posted here
How can I remove mchat from top of forums ?
I would like it on the board3 portal but if this is the wrong place to ask then how can I move it to bottom of forums?
Support Request Support ⇒ How to remove mchat from top of forums (relocate)
Neves
- Status: Offline
- User theme: Dark
- Status: Offline
- User theme: Dark
Re: How to remove mchat from top of forums (relocate)
That setting is in your UCP Mchat tab: Location on the index page: Top Bottom
If you want to set that for all users in ACP Extensions Mchat Global user settings
And ckick both Overwrite settings for all users: Yes Yes
For board3 portal .?.
Neves
- Status: Offline
- User theme: Dark
Wow, that was easy, I overlooked that
