Your phpBB Version:
Your knowledge: Beginner
Disable And enable all extensions
The points seem to work fine and all settings also seem to work but in the forums settings
this is how it displays.
Is that normal ?
FORUM_POINT_SETTINGS
FORUM_POINT_SETTINGS_EXPLAIN
FORUM_PERTOPIC:
FORUM_PERTOPIC_EXPLAIN
FORUM_PERPOST:
FORUM_PERPOST_EXPLAIN
FORUM_PEREDIT:
FORUM_PEREDIT_EXPLAIN
FORUM_COST:
FORUM_COST_EXPLAIN
FORUM_COST_TOPIC:
FORUM_COST_TOPIC_EXPLAIN
FORUM_COST_POST:
FORUM_COST_POST_EXPLAIN
Support Request Support ⇒ Ultimate Points Settings Look Wierd
Neves
- Status: Offline
- User theme: Dark
Azaman
- Status: Offline
- User theme: Dark
Re: Ultimate Points Settings Look Wierd
Same here. No support anymore?
GizmoNZ
- Status: Offline
- User theme: Dark
I'm also having the same issue.
- Status: Online
- User theme: Dark
Looks like language is not in language files, can you check that.
GizmoNZ
- Status: Offline
- User theme: Dark
I downloaded the 1.2.8 again and put all the same files into the same spot but it hasn't changed anything.
samara99
- Status: Offline
- User theme: Dark
The extension versions 1.28 and 1.22 don't work.
An error occurs when enabling it.
SQL ERROR [ mysqli ]
Duplicate entry 'dmzx/ultimatepoints' for key 'ext_name' [1062]
SQL
INSERT INTO phpbb_ext (ext_name, ext_active, ext_state) VALUES ('dmzx/ultimatepoints', 0, 's:13:\"notifications\";')
BACKTRACE
FILE: (not given by php)
LINE: (not given by php)
CALL: msg_handler()
LINE: 1031
CALL: trigger_error()
LINE: 216
LINE: 353
FILE: [ROOT]/phpbb/extension/manager.php
LINE: 180
CALL: phpbb\db\driver\factory->sql_query()
LINE: 242
CALL: phpbb\extension\manager->update_state()
FILE: [ROOT]/includes/acp/acp_extensions.php
LINE: 210
CALL: phpbb\extension\manager->enable_step()
LINE: 684
CALL: acp_extensions->main()
FILE: [ROOT]/adm/index.php
LINE: 81
CALL: p_master->load_active()
SQL
BACKTRACE
CALL: msg_handler()
LINE: 1031
LINE: 216
LINE: 353
LINE: 180
LINE: 242
LINE: 210
LINE: 684
LINE: 81
- Status: Online
- User theme: Dark
delete in phpbb_ext database the dmzx/ultimatepoints and install again.samara99 wrote: May 13th, '26, 12:17 The extension versions 1.28 and 1.22 don't work.
SQL
BACKTRACE
CALL: msg_handler()
LINE: 1031
LINE: 216
LINE: 353
LINE: 180
LINE: 242
LINE: 210
LINE: 684
LINE: 81
samara99
- Status: Offline
- User theme: Dark
I have 2 messages.
My profile says 1. This is incorrect.
How long can I be a new user?
