Support Request SupportProblem with mChat
Support Section
rammstein
Problem with mChat
Post by rammstein »
Your phpBB Version:
Extensions installed: No
Your knowledge: Beginner
Boardlink: https://wawa-rammstein.de/index.php
PHP Version: php 8.0
Non
SyntaxError: JSON.parse: unexpected character at line 1 column 1 of the JSON data
hello
I have a big problem with mchat it's no longer possible to post a message
Re: Problem with mChat
Have you tried re installing a new copy of mChat. and clearing the cache in ACP.
rammstein
Post by rammstein »
Yes I reinstalled everything, nothing changes
rammstein
Post by rammstein »
I found the problem thank you
Whew that's good rammstein I thought I was going to have to jump in and help you out. What was the problem? PHP version?
rammstein
Post by rammstein »
PHP version 8.0
Enable URL rewriting:
If enabled, URLs containing “app.php” will be rewritten to remove the file name (e.g. app.php/foo will become /foo). The “mod_rewrite” module of the Apache server is required to make this functionality operational; if this option is activated without “mod_rewrite” being available, the URL addresses of your forum will be incorrect.
it was on yes I put it on no the mchat works again
satedu
Post by satedu »
Does not display the mChat post clock time next to the user
just like here on the forum
I don't have that
how to restore it :?:
satedu wrote: Dec 27th, '23, 19:11 Does not display the mChat post clock time next to the user
I don't have that
Look in ACP
Also you can set your personal time in UCP
satedu
Post by satedu »
I have everything correct in my site settings
I meant an error in the mChat messenger itself
{%- EVENT dmzx_mchat_messages_before -%}
{%- for mchatrow in loops.mchatrow -%}
<li id="mchat-message-{{ mchatrow.MCHAT_MESSAGE_ID }}" class="row mchat-message{% if mchatrow.MCHAT_IS_NOTIFICATION %} mchat-notification-message{% endif %}" data-mchat-id="{{ mchatrow.MCHAT_MESSAGE_ID }}" data-mchat-user-id="{{ mchatrow.MCHAT_USER_ID }}" data-mchat-username="{{ mchatrow.MCHAT_USERNAME | striptags }}"{% if mchatrow.MCHAT_USERNAME_COLOR %} data-mchat-usercolor="{{ mchatrow.MCHAT_USERNAME_COLOR }}"{% endif %} data-mchat-message="{{ mchatrow.MCHAT_MESSAGE_EDIT }}" data-mchat-message-time="{{ mchatrow.MCHAT_MESSAGE_TIME }}"{% if MCHAT_EDIT_DELETE_LIMIT and not MCHAT_EDIT_DELETE_IGNORE and (mchatrow.MCHAT_ALLOW_EDIT or mchatrow.MCHAT_ALLOW_DEL) %} data-mchat-edit-delete-limit="1"{% endif %} {% EVENT dmzx_mchat_message_attributes %}>
	{% if S_MCHAT_AVATARS %}
	<div class="mchat-avatar">
		{% if mchatrow.U_VIEWPROFILE %}<a href="{{ mchatrow.U_VIEWPROFILE }}" title="{{ lang('READ_PROFILE') }}">{% endif %}
		{% if mchatrow.MCHAT_USER_AVATAR %}{{ mchatrow.MCHAT_USER_AVATAR }}{% else %}<img src="{{ STYLE_PATH }}/theme/images/no_avatar.gif" class="mchat-avatar" alt="{{ lang('READ_PROFILE') }}">{% endif %}
		{% if mchatrow.U_VIEWPROFILE %}</a>{% endif %}
	</div>
	{% endif %}
	<div class="mchat-message-wrapper">
		{% INCLUDE '@dmzx_mchat/mchat_messages_icons.html' %}
		<div class="mchat-message-header">
			{% EVENT dmzx_mchat_messages_header_before %}
			<span onclick="$('#mchat-input').val($('#mchat-input').val() + '[ref=\'{mchatrow.MCHAT_USERNAME_COLOR}\']{mchatrow.MCHAT_USERNAME}[/ref], '); $('#mchat-input').focus();" title="{L_MCHAT_REPLY}" style="font-weight: bold; cursor: pointer; color: {mchatrow.MCHAT_USERNAME_COLOR}">{mchatrow.MCHAT_USERNAME}</span>
			{% EVENT dmzx_mchat_messages_header_after %}
		</div>
		<div class="mchat-text">
			{% EVENT dmzx_mchat_messages_text_before %}
			{{ mchatrow.MCHAT_MESSAGE }}
			{% EVENT dmzx_mchat_messages_text_after %}
		</div>
	</div>
</li>
{%- endfor -%}
{%- EVENT dmzx_mchat_messages_after -%}
where to paste it in the above code
<span class="mchat-time" title="{{ mchatrow.MCHAT_DATETIME }}"{% if mchatrow.MCHAT_MINUTES_AGO != -1 %} data-mchat-minutes-ago="{{ mchatrow.MCHAT_MINUTES_AGO }}" data-mchat-relative-update="{{ mchatrow.MCHAT_RELATIVE_UPDATE }}"{% endif %}>{{ mchatrow.MCHAT_TIME }}</span>
I do not have that code in mine, I am using v 2.1.4
What version of mChat do you have?
This is my code
	</div>
	{% endif %}
			{{ mchatrow.MCHAT_USERNAME_FULL }} &bull; <span class="mchat-time" title="{{ mchatrow.MCHAT_DATETIME }}"{% if mchatrow.MCHAT_MINUTES_AGO != -1 %} data-mchat-minutes-ago="{{ mchatrow.MCHAT_MINUTES_AGO }}" data-mchat-relative-update="{{ mchatrow.MCHAT_RELATIVE_UPDATE }}"{% endif %}>{{ mchatrow.MCHAT_TIME }}</span>
		</div>
		</div>
	</div>
</li>
{%- endfor -%}
satedu
Post by satedu »
I have 2.1.4
I have added the code Mention user by clicking on nickname
but I don't have time to chat right now
Salva66
Post by Salva66 »
Hallo Community!
Gibt es eine Möglichkeit, mChat direkt in der Datenbank zu deaktivieren?
THX 👍
