Support Request SupportProblem with mChat
Support Section
Pingui
Problem with mChat
Post by Pingui »
Your phpBB Version: 3.3.10
Boardlink: https://www.winuaespanol.com
PHP Version: 8.2.7
MySQL Version: 5.6.51-91.0-log
Nothing
Nothing
Hi all...
How are you? I'm very hot right now in Madrid, more than 40 degrees Celsius.... It sucks... xD
I'm writing to you because I have a problem with MCHAT since version 3.3.5. The new version 3.3.7 doesn't work to give colour to the texts either. That is to say, I mark the text I want to change the colour of and when I click on the icon to give it colour, the colour selection window does not open.
On the other hand, in any other part of the forum it does work.
Why is this? I am waiting for your wise help.
Best regards.
Translated with www.DeepL.com/Translator (free version)
Be yourself, except if you're stupid, then it is better that you be another one.
I Amiga
- www.WinUAEspanol.com
I know, my english is very bad, sorry...
