Re: Image Upload
I see you hate to be quoted so sorry about this...
Bruce Banner wrote: Nov 28th, '23, 21:11And now you speak to me as if I should be the one apologising.
PS I notice you never bothered to thank me when I pointed out that error in the code of your UCP Sidebar extension, nor have you corrected the error. You're welcome. I won't ever be contacting you again.
Maybe we both need to apologize.
I apologize for reading 1 MB when you clearly stated 1 GB. I even quoted you in my first response as 1 GB and still it didn't register in my brain.
And after reading it again my brain still registered 1 MB. I promise you, I was being the idiot not seeing your 1 GB. My bad.
But Bruce, please go look at my first response to your question at what I said, "Raise the php.ini to 2 MB" You did not change it.
Martin gives details on what's going on and instructs you to, " Set the php.ini to 2 MB" You did it and it fixes your issue.
I mean what's up with that? Your issue could have been fixed on that first response of I gave you. You could have come back with, "That worked, Thanks"
I thanked you at .com for pointing out that typo in one of the links. Out of 4 years in that topic I had 1 page. Now 5 pages, the extra 4 pages have been from recently giving you support. And my support to you has not been in just that topic but all over. No thanks needed. You chose to go to battle in here with someone that was trying to help you instead of taking the fix he gave you and shaking his hand with a smile when it worked. That's your bad.
No apologies from you needed if you don't feel you need to, you were just flowing with your emotions.
Please let me know if there's anything else I can't help you with.
Re: Image Upload
Sniper_E wrote: Nov 29th, '23, 03:54
I have a sore bum.
Re: Image Upload
Well you're in the right place for that. That is definitely something I can't help you with.
You just need to quite using your wife's sex toys without supervision. LOL
toklat
Re: Image Upload
Post by toklat »
It's not a bug, rather cosmetic.
The commas between the allowed file extensions are not in the right place:
Open /controller/imageupload.php
Line 274:
$imageupload_allowed_extensions = implode(' ,', $allowed_extensions_array);
Replace with:
$imageupload_allowed_extensions = implode(', ', $allowed_extensions_array);
yusufdj
Re: Image Upload
Post by yusufdj »
[progress][/progress]
Re: Image Upload
Progress: of image uploaded
100%
SpIdErPiGgY
Re: Image Upload
Post by SpIdErPiGgY »
Is it possible to use simple header and footer, or non of both...?
It's too "crowded" with that header and footer.
🌐 phpBB Extensions in Dutch
💚 Support this project on Ko-fi
Re: Image Upload
SpIdErPiGgY wrote: Sep 5th, '25, 03:55 Is it possible to use simple header and footer, or non of both...?
What do you mean do you have image?
SpIdErPiGgY
Re: Image Upload
dmzx wrote: Sep 5th, '25, 05:48
It would be nice to have the popup like this:
Instead of this:
Re: Image Upload
imageupload_body.html
{% INCLUDE 'simple_header.html' %}
<form method="post" id="add_imageupload" {{ S_FORM_ENCTYPE }}>
	<div class="panel" id="showdiv">
		<div class="inner">
			<h2>{{ lang('IMAGEUPLOAD_UPLOAD_SECTION') }}</h2>
			<p>{{ lang('IMAGEUPLOAD_UPLOAD_MESSAGE') }}</p>
			<p>{{ IMAGEUPLOAD_ALLOWED_SIZE }}</p>
			<dl>
				<dt><label>{{ lang('IMAGEUPLOAD_NEW_FILENAME') }}{{ lang('COLON') }}</label> <input class="inputbox autowidth" type="file" name="filename" size="52" /></dt>
				<dd><label>{{ lang('ALLOWED') }} {{ lang('EXTENSION') }}{{ lang('COLON') }}</label>{{ IMAGEUPLOAD_ALLOWED_EXT }}</dd>
			</dl>
		</div>
	</div>
	<div class="panel bg2">
		<div class="inner">
			<fieldset class="submit-buttons">
				<input class="button1" id="submit" name="submit" value="{{ lang('SUBMIT') }}" type="submit" />&nbsp;
				{{ S_FORM_TOKEN }}
			</fieldset>
		</div>
	</div>
</form>
{% if FILENAME %}
	<div class="inner">
		<fieldset class="fields2">
			<h4 id="showdiv">{{ lang('IMAGEUPLOAD_SUCCEEDED') }}<br /><br />{{ WIDTH }} {{ lang('PIXEL') }} * {{ HEIGHT }} {{ lang('PIXEL') }} - {{ SIZE }}</h4>
			<p id="codes">
				{% if IMAGEUPLOAD_ENABLE_DIRECT_LINK %}
				<label id="codehtml">{{ lang('IMAGEUPLOAD_DIRECT_LINK') }}{{ lang('COLON') }}</label><br />
				<input type="text" value="{{ FILENAME }}" id="link" /><i class="buttoncopy" data-copytarget="#link">{{ lang('IMAGEUPLOAD_COPY') }}</i><br />
				{% endif %}
				{% if IMAGEUPLOAD_ENABLE_URL_LINK %}
				<label id="codehtml">{{ lang('IMAGEUPLOAD_URL_LINK') }}{{ lang('COLON') }}</label><br />
				<input type="text" value="[url={{ FILENAME }}]{{ lang('IMAGEUPLOAD_BY') }} {{ SITENAME }}[/url]" id="url" /><i class="buttoncopy" data-copytarget="#url">{{ lang('IMAGEUPLOAD_COPY') }}</i><br />
				{% endif %}
				{% if IMAGEUPLOAD_ENABLE_IMG_LINK %}
				<label id="codehtml">{{ lang('IMAGEUPLOAD_IMG_LINK') }}{{ lang('COLON') }}</label><br />
				<input type="text" value="[img]{{ FILENAME }}[/img]" id="img" /><i class="buttoncopy" data-copytarget="#img">{{ lang('IMAGEUPLOAD_COPY') }}</i><br />
				{% endif %}
				{% if IMAGEUPLOAD_ENABLE_URL_IMG_LINK %}
				<label id="codehtml">{{ lang('IMAGEUPLOAD_URLIMG_LINK') }}{{ lang('COLON') }}</label><br />
				<input type="text" value="[url={{ FILENAME }}][img]{{ FILENAME }}[/img][/url]" id="urlimg" /><i class="buttoncopy" data-copytarget="#urlimg">{{ lang('IMAGEUPLOAD_COPY') }}</i><br /><br />
				{% endif %}
				<div id="showdiv">
					<img id="upload" src="{{ FILENAME }}" title="{{ lang('IMAGEUPLOAD_BY') }} {{ SITENAME }}" /><br />
				</div>
			</p>
		</fieldset>
	</div>
</div>
{% endif %}
{% if S_IMAGEUPLOAD_ENABLE_MULTI %}
{% INCLUDE 'imageupload_multi_upload.html' %}
{% endif %}
{% INCLUDE 'simple_footer.html' %}
overall_header_navigation_append.html
{% if IMAGEUPLOAD_USE_UPLOAD and IMAGEUPLOAD_NAV_ENABLE and not IMAGEUPLOAD_CENTER_ENABLE %}
<li data-last-responsive="true"><a href="{{ U_IMAGEUPLOAD_UPLOAD }}" target="_blank" title="{{ lang('IMAGEUPLOAD_UPLOAD') }}" role="menuitem"><i class="icon fa-upload" aria-hidden="true"></i><span>{{ lang('IMAGEUPLOAD_UPLOAD') }}</span></a></li>
{% else %}
<li data-last-responsive="true"><a href="{{ U_IMAGEUPLOAD_UPLOAD }}" onclick="popup('./imageupload', 670, 300); return false;" title="{{ lang('IMAGEUPLOAD_UPLOAD') }}" role="menuitem" data-navbar-reference="imageupload"><i class="icon fa-upload" aria-hidden="true"></i><span>{{ lang('IMAGEUPLOAD_UPLOAD') }}</span></a></li>
{% endif %}
posting_editor_submit_buttons.html
{% if IMAGEUPLOAD_USE_UPLOAD and IMAGEUPLOAD_POST_ENABLE and not IMAGEUPLOAD_CENTER_ENABLE	%}
<input type="button" class="button1" onclick="popup ('{{ U_IMAGEUPLOAD_UPLOAD }}', 670, 300); return false;" value="{{ lang('IMAGEUPLOAD_UPLOAD') }}" title="{{ lang('IMAGEUPLOAD_UPLOAD') }}" />
{% elseif IMAGEUPLOAD_USE_UPLOAD and IMAGEUPLOAD_POST_ENABLE and IMAGEUPLOAD_CENTER_ENABLE %}
<input type="button" class="button1" onclick="popup_center('{{ U_IMAGEUPLOAD_UPLOAD }}'); return false;" value="{{ lang('IMAGEUPLOAD_UPLOAD') }}" title="{{ lang('IMAGEUPLOAD_UPLOAD') }}" />
{% endif %}
popup.center.js & overall_footer_after.html
var h = 700,
		w = 700;
var h = 300,
		w = 670;
Adjust the values if you want multiple upload on.
TomaGo
Re: Image Upload
Post by TomaGo »
Thank you for this extension, it's what I'm looking for to be autonomous on image hosting.
Would it be possible for the BBCode links to be pasted directly into the message being written? Like with the postimages extension but for local hosting.
Thank you
SpIdErPiGgY
Re: Image Upload
dmzx wrote: Sep 5th, '25, 06:19
		<div class="inner">
			<dl>
			</dl>
		</div>
	</div>
		<div class="inner">
				{{ S_FORM_TOKEN }}
			</fieldset>
		</div>
	</div>
</form>
{% if FILENAME %}
	<div class="inner">
			<p id="codes">
				{% endif %}
				{% endif %}
				{% endif %}
				{% endif %}
				<div id="showdiv">
				</div>
			</p>
		</fieldset>
	</div>
</div>
{% endif %}
{% endif %}
Thank you! Just 1 issue ... This edit is losing the ccopy function... Js an css...
Screenshot 2025-11-01 at 11-25-52 phpBB NL Ext Vertalingen • Afbeelding Upload sectie.png
yusufdj
Re: Image Upload
Post by yusufdj »
Can I add a watermark?
lopoto
    Mac OS X iPhone
Re: Image Upload
Post by lopoto »
Does anyone have an HSIMG bbcode for imageupload?
lopoto
    Mac OS X iPhone
Re: Image Upload
Post by lopoto »
It looks like this for me, a link instead of a picture
any tips ?
